Originally Posted by coosawjack
Do you simply mount an electric pump before the mechanical pump and force fuel past the mechanical pump to the carb?? That seems too easy!!
If so I will get a push buttom "ON" switch that is off when released...Voila...no more grinding!!
Coosawjack
A electric pump need to be as close to the fuel tank as possible because they like to push the fuel not pull
