Old 10-15-2006, 12:31 PM
MCOULTER MCOULTER is offline
Default Electrical Problem: Everything Hot
Strange thing happened the other day. I am running an electric fuel pump that runs off my ignition switch. I was setting my distributer and bumping the engine over using the switch. After 1 click the starter continued to turn without the switch (in fact I turned the switch off and it still was turning?).
I was able to stop it by hitting my battery disconnect switch. Now each time I turn on the battery disconnect it turns the motor over automatically without the switch.
I tried replacing the switch - same problem. Could I have a bad solenoid? All wires are coming off the single terminal on the solenoid. I did notice that my electric fuel pump no longer comes on when under battery power?
