True007
I believe that bolt may go allway thru with open end at rear on diff side, don't really remember, been a while since I changed my diff out. For some reason I don't think it was a blind hole. Don't know what the current fix is but it used to be that you drill the hole out and tapp it to the next size of american threads I think it is 1\2 or 9\16 or 5\8 not sure but you can replaced the bolt with a grade 8 quality or better and be thru with it. Might consider going with a solid diff mount while you repairing this problem, pretty sure Reg has them in stock. This used to be the fix for high horsepower cars.
DON
