Old 10-18-2006, 01:29 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Archrms
the first four gears of the Tremec TKO/600 appear to be the same as the Wide Ratio Toploader, with the added benefit of an overdrive. It would seem that the Tremec TKO/600 would be a no-brainer to get the same performance/gear ratios of a toploader with the added benefit of the overdrive.
Yes. With the WR toploader's first gear 2.78, you can use a 3.08 rear, and if you build a BB stroker, I'd run 2.88's in the rear. Then you don't need an overdrive. But , many people are running the TKO600 with 3.54's or so, then the 0.82 OD is more useful. But, with the 3.46 rears, 1st may be a little short, and with the 2.87 first, 3.08 or 2.88 rears would probably be more useful, at least to my taste.
I'd run 3.08's with the TKO600 (0.82 OD), and either 3.08's or 2.88's with the WR toploader.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
