Old 10-19-2006, 12:04 PM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
I am not 100% sure but I don't think that Rotella T is a synthetic oil. However, Rotella T is one of the better oils to use with a flat tappet cam.
The additive that has been greatly reduced in oil is ZDDP. The reduction was at the request of the EPA, I believe. I contacted STP who told me that their "STP Oil Treatment" contains a high level of ZDDP so adding a can of STP with each oil change should increase the level of ZDDP in your oil.
If you like a really thump, thump, thump, sounding idle, then stick with the flat tappet cam. I find that many engines equipped with roller cams have a much more civilized sounding idle. I assume it has to do with the overlap and the profile of the lobes.
Wayne
Don't get caught dead, sitting on your seat belt.
