Old 10-20-2006, 06:34 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Get under the dash if they are functional you should see a small electrical motor near the center or over the passenger side, that's the wiper motor. Not being sarcastic... on your dash there should be either a knob or lucas type switch, on low 1 postion, on high 1 position, then off or/park. The knob will rotate the switch is flipped on, on ,down is off.
Check your fuse block for a blown fuse. All of this is assuming you are the 2nd owner of the car .
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
