Romanbuilt,
My guess your levers are slipping on the rod that runs parallel to your fire wall. I would suggest that either you spot weld them in place or drill a small hole thru the lever and rod and use a roll pin once you get everything in the position you want.
Clois
"Let's roll"
"Be part of Something Good
