  #39 (permalink)
Old 10-21-2006, 01:44 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by double ugly
Well, I went to Checkers and bought Felpro gaskets (20 mile round trip) and by the time I got home the oil and water temps had reached normal temps of 65-70 degrees. I put it on the Quik Lift and a couple hours later looked under the car. The oil spot was the size of a quarter. (can live with that) I figured that maybe the mechanic was right and it was oil residue in the bellhousing working it's way out from a previous faulty rear main. I checked again an hour later and no change in the size. After the baseball game I went out and found the size had increased to half the size of a dollar bill. Crap. Look's like I'll replace the intake gasket but I really have my doubts that it will change anything. Using a Q-tip I found no wetness behind the intake manifold.
John
I am going to do the same thing in a month or two.
Just make sure all your surfaces are clean of all oil and dry. After putting it back together let all adhesives set overnight before firing up the engine.
Good luck
