Old 10-21-2006, 08:14 PM
The experimental alloy 390 was a 427 alloy block 'sleeved down' to a 390 size. Unreliable? I doubt it, no developement time was given to the engine to ever find out one way or the other. Only a few were made, I would bet COST was the determining factor. Thats exactly why GM stopped making the early alloy 215 cid engine that eventually became a ROVER V8 in England. It simply cost to much to make. What about the early experimental alloy heads as well? Very limited in number and I would bet VERY expensive to make, abandoned.
The alloy 390\427 block had little in common with the standard iron 390, just happened to be the same cid. Like the 351Windsor or the 351Clevland, same cid but different engines. I can't imagine Shelby giving any SERIOUS thought to using an original iron 390 for a power plant. All though, no doubt all options were on the table at some point.
