if you have a pre 96 T5 it is a borg-warner, the different size gears are for the different geared rearends and tire height, any of the T5 gears should work and not make a difference in connecting to the drive gear, sounds like you do have a issue with the drive gear, the T5 is a very complicated transmission, you may need to see a good transmission guy
PapaJohn
