Old 10-22-2006, 05:05 PM
FrankJohnson69's Avatar
FrankJohnson69 FrankJohnson69 is offline
Cobra Make, Engine: ERA-722, Pure Street in BRG
Default Starting/running....
Hi Bob,
Well, ERA-722 is alive but doesn't keep breathing. I've got it to start but as soon as you release the key to disengage starter and continue running it just shuts off. I spoke to Peter P. today to see if he had any idea and he said to check the starter switch wiring. I did and it's wired according to the instructions.
Also, the high beam switch on the turn signal stalk doesn't work or something doesn't work to change from high to low beam. Any idea where to start looking to fix that?
I’ve also managed to somehow wire the amp meter backwards. When it’s drawing it goes to positive and when it fires for that second it goes to negative. Is just swapping the leads good to fix that?
I'm not an electrical guy but I'll do my best to understand.
Thanks!
Frank Johnson
ERA-722
