Well I have the fans installed. I ended up using the brackets that came with the finish line kit. I had to cut the fan bracket/angle irons down to the correct length and re-drill all of the mounting holes in the brackets.
I have ran the fan wiring up and under the dash and thru a big grommet that BDR had under the dash in the passenger footwell. I still have to wire the fans in but have that figured out. I have purchased a relay from the local auto parts store. BDR has two spare wires under the dash by the fuse panel that are available for after market items. One is a red wire (12 volt) and the other is a red with blue stripe wire (12V ignition switched). I still have to track down which fuse is used for either of these wires but will figure that out tomorrow night. Anyone know which fuse goes to these spare power wires?
I am going to use the red/blue wire to go to the relay for power and coil excitation and run a ground from the ground coil excitation to the switched ground on the dash that is used for the existing manual turn on fan switch on the dash. That way when I want to, I will flip the switch on the dash and it will turn on the existing puller fan and also the new pusher fans.
