  #1702 (permalink)
Old 10-24-2006, 11:15 AM
Ron61's Avatar
Ron61 Ron61 is offline
Just got back from a drive up to Sears to buy a pair of shoes. I seem to have the fan and charging problem fixed, but I think the thermostat housing has a small seep coming out of it as I find some water and anti freeze in the valley on top of the water pump right under it. Haven't been able to feel any wetness, but that is one of those hard to seal chrome housings and it has held without seeping since 1996, so I guess it is time to take it off and check the thermostat and replace the gaskets. I hate little stuff like that as it just drives me nuts. But the car ran great and I may have to adjust my fan thermostat setting back a little higher. I lowered it when I was testing the wiring and it wants to come on at around 185 now. I am not going to even try to figure out how he wired that toggle switch as it has two white wires that suddenly turn into other numbers and go off God knows where under the dash. I may just unplug them and see if anything stops working. If not, then I can run a couple of colored wires from the fans to the switch and I will know what I have.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
