Old 10-24-2006, 06:03 PM
excessiveHP excessiveHP is offline
Default For exhaust that works awesome
I sent this to Eric at Chassic Chambered exhaust. I thought this might be of interest to others as well.
Hello Eric,
We put the mufflers on yesterday and Holly crap!!!, what a difference I gained a hundred 100hp & 100 Fpt easy. I used to have to use the clutch to get my tires to spin, Not no more, I just tap the gas, and the tires are a blazing even at 30 miles an hour, Just touch the gas and your going sideways. I still can't believe what it has done to my car even Gord said If he hadn't seen it with his own eyes he wouldn't believe it. Its like Nitrous. I ran them in both directions they sounded better in backwards, a nicer deeper sound, and they weren't much louder. We tested them in side the shop with a Db meter, It was a more controlled environment. Readings with stock mufflers were 98 Db @ 2000rpm 110Db @ 3000rpm 106Db @ 4000rpm With the power stix in the right way readings were 103Db @ 2000rpm 108Db @3000rpm 111 @4000rpm with them in backwards they were they were 106Db @ 2000rpm 107Db @ 3000rpm 109Db @ 4000rpm. You have to remember we were inside a shop, When we moved it outside it was a lot quieter.also my idle went up 175 rpm just from better flow. Again thank you I only wish I would have changed the mufflers before I changed my engine It mostly likely had enough power in the first motor .
Thanks again,
Grant Steele
