Old 10-25-2006, 07:28 PM
RedSabre's Avatar
RedSabre RedSabre is offline
Registered User
Cobra Make, Engine: Midstates
Default Clutch won't disengage
Well the clutch is just fine, a little rust on the flywheel & pressure plate. The issue was the slave cylinder did not have a direct push on the throwout fork. Due to the cantilever setup that was originally installed, there just was not enough push in that cylinder to move the fork. Had some brackets made to line the cylinder all up, now the clutch works. Hot dog!
