Old 10-26-2006, 08:42 PM
USrowboy USrowboy is offline
Send a message via AIM to USrowboy Send a message via Yahoo to USrowboy
Default Richmond 5 speed Help needed
Some 4 months ago, a spring in the linkage of my fairly new Richmond 5 speed broke, dropped into the base of the linkage and made shifting impossible. I had to be towed because of a 50cent spring. Removing the seats, tunnel and back panel, as well as the shifter and mounting support cost me 6 hrs of my life.
With fewer than 5 hrs driving on the car since, I have a new problem. There is "play" in the shifter to the tune of 3inches almost in the first four gears and about 2 inches in 5th gear. It is driveable, but since I got it home without a tow, and with the cold coming in, that's it for the (short) season.
Any thoughts on why a shifter might have a lot of "fore and aft" play in the shifter? There is not a problem shifting, and there is no lateral play. The clutch doesn't slip. And in general, it seems fine except when in drive, there is that fore and aft play.
Will this require access to the top only of the trans or are we talking taking the Trans out of the car? Any thoughts, experience in this area would be appreciated.
Thanks
usrowboy
PS: I rarely get aggressive while driving. I'm not a quick starter, maybe a little over the speed limit, but I baby the car.
Ziggy
