Old 10-27-2006, 09:26 AM
Buzzmobile's Avatar
Buzzmobile Buzzmobile is offline
Cobra Make, Engine: SPF 148 with 427 SO
yes, the pins are just "sleeves" that screw down on the normal studs the lug nuts go onto and you torque them to 80. As for is it worth it, can't answer that in a simple yes/no answer. I have had ears break off the spinners by taking them off...but I had defective spinners. But, the tool places the force on ALL the wings of the spinners at the same time with removal, so you can put more force to it while removing without breaking the wings. that is probably why they do not recommend using the to to put it on...you could way over tighten.
Buzz
