Originally Posted by dlampe
Thanks Bernie, that is EXACTLY what I wanted to see. It looks like the webers will win up to 6800. I looks like the webers were done at 6800 and went south while the holley was still climbing. It also looks like you are running more cam than most weber guys recommend. What is your overlap and LSA? I thought about 240 @ .050 was about the max. Are you happy with the way it runs? What chokes are in your webers? I could live with the webers if I had your numbers. Lastly, what effect will more cubic inches have on the performance difference between the carbs? This info is a huge help to me.
42mm choke,107.0 lobe deparation,cam installed@105.0 centerline
F 16 ,160 M, 130 A
I think over 400 CU Holley are better.Weber are too testrictive on the choke size (maxi 45 mm) interesting to test with enlarged the bore from 48 to 51.5mm or BERG expensive solution up to 58mm choke
