Old 10-31-2006, 04:16 AM
Default Nascar rods
1nce bitten You know that nascar rods need a different crank because the rods are wider on the bottom to help with those high rpm races. The ID # isC9AZ-6303D , the rods are C7OE-6200A. The crank and rods are .080" wider. These rods are also 1000 grams each. Hang them on a wall and go with a BBC crank, rod and piston. You will need a wider bearing which is made for these rods. You are pretty limited here too. No body sees your rods in the bottom end. Just a thought. Rick L.
