Old 11-01-2006, 04:24 PM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Default PCV valve AND breather cap too?
My friend's 460 has a PCV valve hooked up to vacuum at the carb base, AND a breather cap on the other valve cover, but the cap is the type with a hole on top; and you can really see the blow by at idle.
My 460 has both as well but the breather is the type where the vent is under the cap, venting at the base of the cap.
Are both necessary? Doesn't one negate the effect or effectiveness of the other?
Insight from 460 gurus would be appreciated.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
