Bret, are you running a 950?
1. I'm regulated at 5-6psi using same regulator as Morris. Line sizes per Mallory's recommendations.
2. Idle settings are fine. In fact, my a/f ratio is fine at idle. The problem is after I'm out of the idle ckt, but before WOT. Ie, cruising sucks.
3. I'm at Kentucky altitude.
4. The problem was worse with the originally installed jets. They were 4 sizes larger on front and back.
5. My shooters are dialed.
Morris, see #2...idle is okay.
Thanks for the help! Again, PV is the only thing I think I'm out of line on (@2.5).
Joe
