Thread: Feeding csx4788
Old 11-02-2006, 09:40 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Sometimes 90's can't be avoided, such as the 90 fitting feeding the fuel log on wtm442's small block. But he is right, as a rule the more 90's in line the more flow restriction realized.
A single 90 in a low pressure system conducting a fluid with the viscosity of gasoline is of no consequence. Now if you are pumping oil at 100 psi that changes everything, I was careful not to include any 90 degree fittings when designing my oil circulating/cooling system.
