Also, You guys mill the tailshaft as well as a small portion of the top shift plate. You must dissassemble the tailshaft and toplate to do that. You then have to reassemble it. That is why Tremec is saying they can't cover it. You are an authorized distributor, but why don't they feel comfortable enough in you work to cover it. They will cover the transmission if it is raced at the track. Just look at the ad the have. If they stand behind their transmission, why can't you?
Greg.[/quote]
Who ever you talked to at tremec has obviously misinturpreted the warranty. As all transmissions we do are still under warranty by tremec taking the tailhousing and topplate off has no affect on the internal gear set and is still under warranty from tremec. We do cover many transmissions and tremec sends us alot of customers to us to warranty for them direct. Also if you call the tech line and tell them you broke your trans drag racing they do not cover that I am sorry if they mislead you but that doesnt happen.
