Hi Cody:
Was your problem ever solved? I have the same issue. The pads are worn, but not excessively. Mine are about 1/8 inch thick. It seems the spring which pushes the pads away from the disc is too thick. The pads cannot contact the rotor because the spring is collasped and cannot contract futher. Maybe the pads are suppose to be much thicker than an 1/8 inch.
Tom
