PCV or Vent Tank??
The motor is a KC built Pond 482, hydraulic roller, stage 2 Eddy heads, 252/262 IN/EX Duration, 633 Lift, 112LS, with 625HP&FtLbs, Pro Systems 4V.
Will I have enough vacuum at the carb base to run a PCV set up, or should I just go with a vented separator tank?
Thanks,
Brad
