Old 11-06-2006, 03:53 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by LuvDaBlues
Yep,
I think your correct. Looking under the car this morning I've found a "mid-size" puddle of coolant, and a small puddle on the block behind the water pump, right below the head. Not sure if from the intake or head. Pretty hard to tell. Any suggestions where to get gaskets? High performance, or standard?
Steve
If you're changing the intake gasket, be sure to get the NAPA Victor Reinz one, and use "right stuff" around the water ports. Check out this thread for torqueing sequence:
http://clubcobra.com/forums/showthread.php?t=73499
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
