Old 11-08-2006, 11:02 AM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Default Suspension Setup...whats "right" and how do you dial it in??
I have been taking notice of commentary on the wide varieties of suspension setups available and how, if improperly adjusted, said setup can be called anything from great to stiff to bumpy to scary to dangerous.
Say you have just taken delivery or finished construction of your Cobra, as far as handling and suspension, what should you do now for proper and safe adjustment... and how do you go about it?
My knowledge of tuning in a suspension is limited at best, a lot of reading and limited trial and error. What feels right is not necessarily the safest or best adjustment for any specific car.
I know the engine weight, placement and its torque capabilities has a major influence as well as the style of suspension you ordered/installed, whether you are runing a solid rear axle or IRS, tire type and wheel size, and type of driving the car is designated for.
Can someone offer up an accepted or tried and true process, maybe step by step (?) through which you can find the optimal setting for your car given?
450+hp in a light little 2400 lb. like car like a Cobra is a challenge to begin with, a well tuned suspension it seems has to be part of the "big picture".
Mark
