  #148 (permalink)
Old 11-10-2006, 08:46 PM
craigayl's Avatar
craigayl craigayl is offline
Cobra Make, Engine: Superformance Cobra SC, 514CID
Yes Anthony "the same failure"
Note that on the forward side of the main shaft gear the teeth are copletely gone and on the rear side the teeth are full as if they were not in contact with the countershaft gear. The oposite is true of the countershaft gear. A more indepth investigation is necessary. If these gears were properly aligned, the teeth should have come off more evenly.
Craig
