Excaliber: No, the mounting doesn't seem to be the problem. The overall depth of the alternator is the issue.
Burgs: Adding spacers will only push my alignment off further.
Lineslinger: With the 80 amp alternator were you able to run an ampmeter or did you have to change to a voltmeter gauge?
Blykins: What is the dimension from the very back of the alternator to the center of the v-grove. Is this a 1-wire alternator?
