Old 11-13-2006, 05:46 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Here's a closeup of the front pivot less shims on the back side. Rear pivot looks the same. I'll post an overall picture, too.
Guess what I'll do is loosen the pivot bolts, fit the shims in real tight, then secure the bolts. I'll have to saw off a short section of hex to fit the socket-head bolt and use a box-end wrench to loosen and tighten bolts. Next stop will be the alignment rack to see where the steering wheel, caster and toe ended up.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
