  #172 (permalink)
Old 11-14-2006, 06:31 AM
keislerNick keislerNick is offline
Well yesterday I was replacing a case on a transmission for a customer he had broke the mounting ears on the front of the main case. Interesting thing was he broke it because the driveshaft broke hit in the tunnel a few times and ended up breaking the trans case and the starter ears to. This however was a TKO 1 older style was in a early 90s turbo mustang making over 750whp on the dyno running 9.35 at 138 fairly consistent with the tko 1 trans. So I think they will hold up and many have ran great times with these transmissions.
Now with the g-force someone had posted about whatever they use in the case to avoid gear climb and so on. If you have a tko and you are looking for the g-force alternative and like your tko Pro-motion industries has run 9s with a tko 500 trans so they offer the same high performance drag application. They have an internal cage to stop gear climb along with the kryo treating and many other options.
