Hopefully this will clear that up. The tko1 was still a 3550 trans the older one still used the 3 peice countershaft. Now the only issue I have ever seen with those was they had a key way in those that would sheer so people with those should use promotion industries they will key the full length of the press on then weld and remachine and thus make the 3 peice stronger. Now on the TKO 500 and the 600 only one peice countershafts should be in them. You should not have a 3 peice in a 500 or 600 model.
