Headlight switch
I'm thinking about using toggle switches with the illuminated LED tip. I'm having a hard time locating an ON-ON switch with the LED to use for my high/low beams. I'm going to use the standard "pull-type" headlight switch to the left of the steering column along with the toggle. Does anyone know if you can wire an ON-OFF toggle so that your low beams are on when the toggle is off and the high beams are on when the toggle is on? Thanks...
Mike
