If that piston/ rod is being sold as a SOHC set, I think the seller is ill informed. That appears to be a Rod and Piston from a Boss 429. Completely different. The single piston lookslike one, but the set is definetly Boss 429. Look at the 2 pistons and you can see that the upper one has the valve reliefs perpedicular to the pin line. the Boss piston has the valve reliefs "rotated" off the center line..
WDZ
