11-18-2006, 07:42 AM
6th Generation Texan
TX
Kristen,
You're right to go around the water with street tires.Not a good idea.The grooves will hold the water and not burn off during the burn out.Can easily make the traction worse.
Don't worry about the run distance being shorter.Just can't get up to a higher speed.Without a doubt there are a lot faster cars out there than the Cobras.You will most likely go thru the lights in 3rd gear.
