GOOD CALL Barnsnake, a known problem with top loaders. The rubber boot puts pressure on the gear shift. IF it pops out enough times it can damage the trans to the point where poping out might happen regardless of the boot.
Just loosen the screws holding the boot in place and let if 'float' with the gear shift to see if it helps.
