Old 11-21-2006, 03:07 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
^ That is a good thing to check first.
Do you have a Blow proof belhousing? Did you check the alignment on it?
I had that happen to me and it was the bellhousing alignment. This can cause the hard shifting too.
The input shaft is put in a bind with the mainshaft when the bellhousing is out of alignment.
