Old 11-26-2006, 08:24 PM
stallion112's Avatar
stallion112 stallion112 is offline
Cobra Make, Engine: Kellison Stallion, 429 SCJ,
Neutral
Question Electric fuel pump
I'm running an AC Delco EP12S electric fuel pump rated at 5 to 9 psi with a Holley 750 cfm. The pump is supposedly good for carbs without needing a fuel regulator. Is anyone else running this fuel pump with a carb and do you have problems related to too much fuel pressure?
Also, some regulators are available without needing a return line back to the fuel tank. Do these really work or are you better off just going with a regulator that uses a return line?
Stallion112
