With the power that you are making and the G forces that you will generate you will have no problem with your set up. You have fixed the pick-up problem which can be a problem on some of these cars. Make sure the tank is vented good as well. The fuel log is a good ideal with any indurance type racing set up. Good luck, Keith
Keith C
