Thread: Wiring Harness
Old 11-27-2006, 02:35 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
The Ron Francis Wiring harness from A & C is from American Auto Wire.
I got mine from A & C, no regrets, spent a lot of time worrying about "Could I do it".
Once you lay out the wires and get a good understanding on how to run the wires thru the car, it goes pretty easy.
I put grounds up front, on the cowl bar and out back. I also soldered all my connections where I was not using connectors supplied in the kit.
Tested all the connections with a 12v battery charger on low amps.
Comments from some people about the wiring in the engine area are rewarding.
You see some builds and they look like they just didn't care about it.
Just take your time and it is no big deal.
At least I didn't burn the car to ground, but I can tell you before I started that's what I thought would happen.
Good luck,
Jim
OhioCobraClub.com
