I'm having the same issues with my Galaxie toploader. There are several options, including a spacer/plate assy that places the shifter more toward the rear. If you are using the same trans & shifter, it should be centered enough. My problem seems to be getting the shifter positioned rearward on the tunnel. ERA recommends using a Mustang tailshaft, but my unit is complete from a Galaxie and I might just use an aftermarket shifter (reverse bend). I'm still working out the problem.
Kee has a phone hotline to answer quetions...just go to the link and call them.
