I was originally scheduled for Sat on the Sept event. For some reason, I had it in my mind that I'd changed to Sun when I moved it to Dec. So showed up and found no confirmed spot, but they worked me in when they had a cancellation. It was pretty full, so I think I got lucky!
Johan, good to hear from you. I'm going to be taking all the tires and wheels off anyway and putting the street set back on. I think I've got a clearance issue as I found there's only about 1/4" between the inside edge of the tire and the wheel well.
That said, I think I need to just have someone give the whole suspension setup and good check and adjust as required. Planning on going to Gran Turismo, but appreciate any suggestions on other good places to go.
Thanks!
Scott
