Old 12-06-2006, 12:46 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
As Michael says, you can leave it out. But when using the valve at the back of the block, make sure you install it in the correct direction. If you don't, the engine won't build oil pressure. If for no other reason, that's a good one to leave it out . . . uh, replace it with a plug.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
