Old 12-06-2006, 05:55 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
This by-pass valve, or relief valve in the lower left side of the block at the rear, either must be installed or replaced with with a plug as described by Michael. After you install the relief valve or plug replacement, seal the oil gallery with the plug.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
