disc brakes & master cylinder problem
My friend has a Cobra with Lincoln rear 11" disc, Mustang front disc and two 3/4" master cylinders. The problem is weak brakes that improve if pumped several times. After we bled the brakes, With the brakes applied, I could turn the rear rotor. I think he needs a larger master cylinder for the rear and adjust the balance bar. What do you think?
Dwight
