Thread: Leaking TKO600
Old 12-08-2006, 12:29 PM
billyboy billyboy is offline
Cobra Make, Engine: BDR #89 427 KC alum
Originally Posted by Jimi G
Most of the GM and Ford transmissions are made by Tremec and Borg Warner was bought by Tremec also. As for a six speed you will want to make sure you have enough room in your tunnel area because the 6 speed is quite a bit larger than your 5 speed. jimig@standardtransmission.com
Thanks Jimi, Glad to have your support. I will take pictures when I pull the trany and post them as I follow your instructions. Might help others with leaks.
