Old 12-09-2006, 09:16 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Default Do you think this will work?
To keep my engine from blowing oil mist out the breathers and all over the engine I rigged up this configuration, the small canister on the back has a one way filter disc in it, as well as some stainless steel wool, the disc will allow gasses to pass through it but not liquids, so in theory gasses only will be carried through to the intake but any oil or oil in the vapor will be restricted/contained in the lower end.
I am assuming there is enough vacum as well as enough crankcase pressure to make let this configuration breath/circulate properly, what do you guys think, I would like to hear your feedback.
Mark
