Originally Posted by Clois Harlan
Another thing to add is that no matter what you use to cut your hose with be sure and clean the inside of your hose before your final connection. I like to use a coat hanger with a piece of cotton soaked in mineral spirits attached and then an air blow gun.
Clois
Good point. As careful as I am when doing this, I managed to miss a small piece of wire filament when I recently changed over to -8 fuel line. Got about one block from the house and the carb flooded over. The filament hung open the primary needle & seat. Better to have been stuck there then ingested into the engine.
Also, no one has mentioned name brands. I personally always insist on Aeroquip. You pay a little more but their quality is unsurpassed. I don't like to skimp on fuel and
oil lines/fittings...too much to risk.
Great thread and awesome photos from Morris.
Regards,
-Dean
