Old 12-12-2006, 08:00 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
The answer is an overwhelming resounding YES. The length of the input shaft on most any transmission you would use takes into account the thickness of the block plate. Omitting the plate could jam the pilot shaft too far into the pilot bearing. Plus, the block plate is a good aide to help keep dirt and other unwanted garbage out of the bellhousing and the clutch.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
