Old 12-13-2006, 06:49 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Part number for throwout bearing
Anyone have a part number for the right throwout bearing for a Tremec TKO 600 hooked to a 427 FE? Ideally Centerforce, since that's the pressure plate/clutch I have, but other brands are fine as well.
Thought this would be a straight forward search on Summit, but all I get is hydraulic concentric bearings.
Also, I assume the shaft size they are looking for is the input shaft vs the diameter of the bearing housing that the bearing actually rides on?
Thanks!
Scott
